Re: Farmall B Starter
Posted by Red Dave on January 27, 2013 at 13:09:43 from (98.235.13.108):
In Reply to: Farmall B Starter posted by Vette Man on January 27, 2013 at 07:37:30:
third party image
I went out to the shed and got a couple pictures of the starter set up on my 1940 Farmall B.
Jim Becker or Gene Bender can verify whether it is the factory stock set up or not.
As far as I know, this is how they came from the factory.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
