As stated before, remove lifters and oil pump, then try to pull out from the gear end. If you try to pry on the gear you will break the gear and/or camshaft (ask me how I know). If push comes to shove, on the back side of the cam is a plug, like a freeze plug, it can be removed and the cam can be tapped out from the rear. I had a C113, that had sat for a loooong time and everything was seized. Be patient and good luck with it.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
