BT, As you know Ms and Hs didn't come from the factory LP equip-ed! They were Field-converted at the local farm-stead by that farmer or there were certified IH mechanics that came to the farm and converted that tractor and in some instances had IH approval to re-stamp the tag! You can do an H conversion there at your farm. The problem is finding a tank that was used on an H or 300 The carb and regulator set up from a a 300 is your best bet. Being in Up State NY there are just not that many LP tractors around. Where in In Texas/Okla and the Deep South they littered the land scape at one time. It takes a little more time and effort to find one, they are still out there, Just a little mopre difficult to locate, and a little more bird dogging in necessary. SM-LPs both Stage I & II I can put my hands on today. 300LPs still fairly easy to find. 350LPs one very elusive tractor less made of that than the SMTAs 400/450s can be found too. Put your nose down and keep looking. Build an LP H would be fun and challenging. But you need one factory LP tractor in house first to give you a visual reference for your build! Hope this helps Later, John A.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
