Re: Need Battery Cable Lengths for Key Start Farmall 140
Posted by DeltaRed on January 04, 2013 at 07:20:28 from (67.6.219.50):
In Reply to: Need Battery Cable Lengths for Key Start Farmall 140 posted by RTR on January 04, 2013 at 06:34:07:
If the tractor is close,the easiest/best way is to
simply measure it.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
