Re: Frustration
Posted by Zachary Hoyt on January 01, 2013 at 04:51:56 from (173.84.189.49):
In Reply to: Re: Frustration posted by BOB HAWBECKER on December 31, 2012 at 20:04:40:
Thanks, I did check that but it is clean and I had the pipe off it anyway to check the suction on the carb inlet.
Zach
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
