Posted by S2710 on December 31, 2012 at 19:17:22 from (98.143.227.89):
In Reply to: Frustration posted by Zachary Hoyt on December 31, 2012 at 17:57:44:
Zack I had a engine that the plugs looked good and I cleaned them and heated them and it still would not start. I put in a new set and it fired right up. I let the tractor warm up good and then put half of them in and it started and missed a little and then it smooth out and ran OK. then I replaced the other two and after that it started OK.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
