Posted by Janicholson on December 31, 2012 at 18:30:59 from (74.60.94.18):
In Reply to: Frustration posted by Zachary Hoyt on December 31, 2012 at 17:57:44:
If it is pulling a vacuum on your hand, it is going to have compression. If the spark is getting t the cylinders at TDC it is going to be assumed that the system is correct. Two things then stand in the way. one is fouled plugs. They might even look perfect, but need to be heated with a propane torch till the little ground electrode is very hot, and the plug smokes some. Put them in warm, with a rubber hose to keep your hands from getting toasty. Use a squrt oil can with gasoline (2stroke is great) in it to put two pumps into each cylinder before the plugs go in. If it fails to keep running then it is some major plugup in the carb. Merry new year, and I hope this helps. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
