Carbon comes from gas that isn't burned completely. Usually from putting too much gas in through the carb.
You'll always have SOME on an old tractor.
Are you leaving it choked when starting it? Open the choke up immediately when it starts.
Also might want to try leaning the carb a bit.
If you do that - be sure to test it under load to be sure you didn't make it too lean. And also check your plugs occassionally to be sure you're not running too lean.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
