Susan - As the others suggest, work the tractor HARD for 10 - 15 minutes (run it wide open and with as much load as you get manage). Then allow it idle no longer than a minute or so before shutting down. This will burn out every trace of moisture and gunk from and leave the manifold/muffler dry inside.
Now presuming there is no coolant leak in the head your next startup will be "clean".
ALSO if your tractor has an inoperative thermostat - or if the t'stat is missing - install a new one so the engine operates at the correct temperature.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
