Posted by Janicholson on December 23, 2012 at 16:28:40 from (74.60.94.18):
In Reply to: Super M trans posted by Chester5731 on December 23, 2012 at 16:01:17:
There are two reasons to consider not doing it. The first is that the trans will make more noise. The second is that it will leak more profusely. It is a high pressure lube and would work fine other than that. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
