A machine shop is exactly who you need to go to to get the shaft fixed, if you can't find a good used one anywhere and you want it "right."
They would build the shaft back up with weld, then turn it round, and mill in the splines. However, that is *VERY* labor intensive and will probably cost you several hundred dollars unless you know someone who owes you a favor.
Frankly, I would probably try the beer can fix first. That's wrapping a shim made from a cut-up beer can around the splines to take up the gap. Make sure the yoke is clamped tight, and check it periodically. The reason the splines are worn is because someone let the yoke get loose.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
