Well if it has never had the valves run in them hours she is way past due, BUT don't expect a this to cure your cold starting problems. The 361 is a fussy engine and IF she is getting a little tired then she is not up on compression.With age the valves ware deeper into the valve seats and this drops compression and wornen rings along with sleeve ware don't help . Then we get into the injectors as like everything else they don't work like new anymore either and you also have no idea as to what the cranking pressure of the pump is or how fast the starter is turning the engine over. Are your batterys up to snuff?? do they have the correct cranking amps ?? are your cables the correct size . My 806 is like me it does not like cold weather either. But add a little warmth then she is ready to go.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
