You have probably seen my posts on Char Lynn over the last couple of weeks. I've finally gotten mine up and running.
Does yours use it's own pump or a diverter from the hydraulics? There really isn't anything in the torque motor to go bad. I would suspect the supply. If it has it's own pump it could have a plugged filter and be starving for fluid. If it is off the main hydraulics your pump may be getting weak. Is it only at lower idle? Only after it is hot? Is it better in the cold weather?
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
