Almost all canvas type systems can be customized to fit. Cut as needed and pin together with "T" pins. Join with urethane door and window sealer and let set for 24 hours. Brackets and hardware are usually adaptable to be sturdy. Make attachments rigid so that the components do not flop around. Also make sure the canvas does not get tangled or intrud into the pedals. Canvas used under the tractor to "close the bottom is often very helpful in keeping you warm. Jim
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
