About the only thing that may be a bit out of the ordinary in replacing the M clutch without splitting the tractor is that you remove every other PPA mounting blot and install them back into the pressure plate to compress the springs. Other than that it is a matter of removing the LiftAll pump, disconnecting and removing the drive shaft coupler,release the clutch pedal return spring, and remove the two bolts that hold the release bearing pilot tube to the clutch housing. At that point you can usually remove the drive shaft from the clutch disk. Some times you have to remove the other three bolts from the PPA to be able to slide the shaft out. Once the shaft is out the PPA and disk will come out.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
