Re: 706 Engine Identification
Posted by mazemeister on November 08, 2012 at 14:18:29 from (24.187.98.163):
In Reply to: 706 Engine Identification posted by John_B on November 08, 2012 at 12:43:00:
263 or 291 on the gasser, diesel were 282 or 310. there was a serial number break at some point when they switched to the larger engines.
S-Y suffix indicates you have a TA and 12 gpm hyd pump.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
