You had it in correct, as you can see it will not go the other way. If that tube fits into it's hole in upper housing freely it will more than likely leak around it and definetely not stick.
Here is what I would do now that you have it off, is take fan belt off so water pump won't turn, fill as much coolant as you can get in right at the engine. Start engine and coolant should not move. If it rises up you have a combustion leak causing heating problem. You have to do this quickly as it will start to rise as soon as it warms so you have less than maybe a minute to take a look.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
