Posted by The tractor vet on November 02, 2012 at 14:40:31 from (75.24.0.62):
In Reply to: 706 Gas Tractor Quit posted by Tobaccoman on November 01, 2012 at 18:25:35:
IF the shut off solenoid goes bad then they will not run . And do not replace with a half arrsed fuel metering screw , that soleniod was put there for a reason . Check with a test light to see if you have power with key on , if you have power then remove the solenoid and ground it and turn the key on to see if the pintel moves in . NOW BE CAREFUL as not to cause a spark with gas layen around or you just may be getting a new tractor and building . The pintel (needle) should move in about and 1/8 to 3/16 of and inch so that you are in full fuel and seat in the main jet to shut off fuel with the key off so that you do not have run on when the engine is HOT . Now maybe a good time to remove the carb and do a tear down on it and give it a good cleaning and check for dirt in the main jet area.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
