Posted by kopeck on October 31, 2012 at 09:54:55 from (169.244.197.208):
I've written about my '47 A a couple of times on here recently. I've received plenty of good advice but nothing seems to be curing my A's miss. You can see where I've been here:
Since that thread I purchased another Zenith, cleaned it up my self and then bit the bullet and sent the parts out to have a pro look over, install new throttle bushing and reassemble.
The results are pretty much the same. Idles like crap/can barley keep it running and starting can be tricky too. WOT is usable but still seems kind of "strained" and there's still a miss.
It still feels like fuel to me but I'm out of ideas. At this point I've:
Tried 3 different carbs, none of which made it "right".
Tried running with the air cleaner disconnected
Tried the propane test to look for leaks
Each cylinder has 94 lbs (give or take a pound) of compression with the engine warmed up.
I've checked the valve lash and everything is set to spec.
New point and condenser (H-4 Mag), tried a different set of wires and 2 news sets of plugs.
At this point it almost seems like it has to be ignition related. The H-4 makes good blue spark when I turn it over by hand. I've toyed with getting a battery ignition for it for a while, I think they run a bit better then the H-4s BUT it still should run well with the mag.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
