Take the standard wireing diagram, eliminate the wiring for the genny and VR. Build new harness without wiring for charging system. Add in wire/wires needed for the aleternator. Should work just fine. Just make sure everyting is hooked up as it should be.
Basically you should have a hot wire to the ignition switch from the battery terminal on the starter, a wire from the ignition switch to the coil. A hot to the light switch again from the starter terminal. Positive cable from a 12 volt battery to the starter and the - to a good ground on the tractor. One wire alternator goes to the amp guage and from there to the hot terminal on the stater where the batt cable is hooked up. A 3 wire alternator should have another wire to the ingition switch. Lights should be wired the same way as from the factory.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
