Re: F20/Regular sleeves
Posted by F-Dean on October 22, 2012 at 10:57:12 from (70.194.67.120):
In Reply to: F20/Regular sleeves posted by Fixerupper on October 22, 2012 at 10:50:54:
Yes, they will interchange. You may want to get a new "O" ring for the bottom of the sleeve when you insert it into the Regular.
Rice Equipment has them.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
