Re: wheel seized
Posted by jim warehime on October 20, 2012 at 06:39:35 from (174.252.97.142):
In Reply to: wheel seized posted by PerryC on October 19, 2012 at 17:51:56:
It could also be the bearing at the end of the axle shaft has come apart,had it happen on a m I looked at few years ago. Jim.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
