Can't be a very big piece if its between the flywheel and the steel plate on the rear of the engine. Trouble is even a small piece could wedge in the space. Right between the engine and flywheel the only things to catch on is the bolt heads mounting the steel plate to the engine and the rear main seal housings. After removing the bottom plate. Think I would try to see if a stiff wire or a long thin flat piece of metal would go up and dislodge the piece before spliting. Also a couple of places in the clutch housing on each side of the flywheel for a piece to rest on.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
