Re: Super C Camshaft Gear and Distributor Drive Gear
Posted by Andrew Z on September 19, 2012 at 05:11:28 from (72.10.122.33):
In Reply to: Super C Camshaft Gear and Distributor Drive Gear posted by Smith1000 on September 18, 2012 at 18:15:04:
The cam shaft gear will pull off fairly easy with a
a decent puller. The crank gear can be done as well
just not easy at all, lack of room etc. As El toro
says you may have to press the crank gear off. As
for why they went out, most likely 60 years of use.
I have done this on a few Super C, C's, and a Super
A. Last one I did was a C, did the exact same thing
as yours did but took the pump gear with it as well.
Andrew
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
