Posted by Jon Hagen on August 31, 2012 at 11:17:20 from (69.26.17.61):
In Reply to: 300 ignition posted by Dave8N in Pa on August 31, 2012 at 10:49:40:
IF the tractor has a SI series Delco alternator, the link below gives a good wiring diagram that works with most gas engine tractors with distributor ignition.
The high charge rate on a SI series Delco can result if the Sense wire (marked #2 on the alt rear case) does not have a good connection to battery voltage. This wire is what tells the alternator what the electrical system voltage is so the alternator can adjust it's output to produce a constant 13.5 -14.5 volts. If the #2 sense wire has a bad connection or is not connected to the battery / electrical system, that will cause the alternator to charge at maximum output all the time.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
