Posted by Phil Tibbetts on August 26, 2012 at 05:25:17 from (208.93.14.38):
In Reply to: Re: Ether posted by oldtanker on August 25, 2012 at 23:05:27:
That is what I find. If temp is above 40 nothing needed. If colder just a puff of ether and they fire right up. Used it on lots of tractors with no problems. The key is not to over do it.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
