Posted by pete 23 on August 22, 2012 at 18:49:36 from (74.32.238.2):
In Reply to: Re: my new 1566 posted by Allan In NE on August 22, 2012 at 06:18:23:
By golly Allen, got to disagree with you on this one. That indeed is a filter. It really cleans up a system that is full of crud. I used to install the kits on tractors that were a few years old and that first couple of filter changes could be plugged solid. One guy hooked one up backwards and it completely plugged the inside of that element. You could just tell when you drain those engines, the difference in the looks of the coolant in the bucket. Even with out cavitation protection I would say they are a great thing to have on any tractor, gas or diesel.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
