Posted by dej(Jed) on August 22, 2012 at 05:31:18 from (141.189.251.1):
In Reply to: Fuel in crankcase oil posted by WVFarmall on August 21, 2012 at 18:03:30:
It depends on how much fuel in oil you are talking about. Fuel in oil dillution occurs every time you start up. It is worse in the winter when you crank the engine a lot. You always get some fuel, gasoline or diesel, that gets sent into the engine oil. Pump seals and bad rings are the most common problems when you have severe dillution.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
