Well IF the pilot bearing is seized and causing the problem by not fixing the problem IF you do get it to break free it will take the end off the input and that is part of the T/A If it has one . But before you get all hipper why not just drop the plate off the bottom and look up in at the clutch and see what is going on . It could be that the throw out bearing seized and went thru the release arms., could be that the clutch disc is stuck to the flywheel and in this case i would stuff a three 1/4inch nusts under the release arms and unbolt the pressure plate and pop the disc loose.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
