Re: 300 u manual steering
Posted by ken house on August 20, 2012 at 09:19:27 from (173.242.240.50):
In Reply to: 300 u manual steering posted by craig 300u on August 20, 2012 at 09:17:17:
make sure that the gearbox has plenty of oil. and that the king pins are greased well.
jack up the front end and try turning to see if right turn is tight.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
