Posted by The tractor vet on August 15, 2012 at 07:44:23 from (76.212.225.255):
In Reply to: smd-ta hyd. posted by william nickles on August 14, 2012 at 17:59:40:
Have you plugged a gauge into the remotes to see what pressure you have there Ya only need three gallon a min. for steering . What implements are you trying to raise and what size cylinders are you using . Your working with a low pressure system and a tractor that is old . Plus the fact that that SM/TA diesel has more then likely had extensive field testing thru it's life and your problems may be due to a plum slap wore out pump .
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
