Hi Steven, the PTO clutch could be stuck. Re transmission clutch slipping, the pressure plate fingers are adjustable thru the clutch inspection plate on bottom of clutch howsing. The dual stage clutch is more difficult to assemble and adjust than single clutch, see following from Bernard le mecano: Hi, you can place all the clutch and pressure plate on the shaft and bolt the engine to the rear end. If you remove the PTO clutch, make sure to align the clutch carefully in the center of the pressure plate, before replacing the bolts on the fingers, for that, remove the flywheel, place it on flat surface, put the transmission clutch, the plate, belleville spring, plate, PTO clutch, then pressure plate, belleville spring and cover. Align all of the parts, put 3, 5/16 long bolts and hand tighten to the flywheel. Secure the 3 bolts on the fingers and jam nuts, then adjust the gap. Make sure to adjust the 3 fingers at the same level. The gap for the 3 bolts is .090 inches. Remove the pressure plate, replace the flywheel on the engine crank and finish the job.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
