Posted by FC Andy on August 06, 2012 at 16:23:26 from (74.126.84.52):
In Reply to: Used a case to rake hay. posted by Kevin B from Illinois on August 06, 2012 at 13:47:52:
Yep, Those powershift case tractors really jump when you shift them- But, I always felt that if it jumps you when it shifted, it didn't slip- and I like that. It may be some shock load to the rear end, but the tractors I've been around handeled it just fine. But, I'd also say, at least the upshift on a hydraulic TA is pretty firm, too. I liked the power assist clutch on my cousin's 1570- once you got used to it, it was so slick. And the 3 gears to powershift up through is nice when pulling stuff on the road. -Andy
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
