That sounds very reasonable, since it didn't run for 2 yrs. Humidity in the cylinder could be the cause of it oxidising a bit (my thought) I have to wait a bit for my Spark Plug Box Spanner to be delivered from England (Here all is metric and impossible to order a 1" - 7/8" box spanner)Thanks a lot! will check back after installing new spark plugs.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
