COmbinations of bad things happen when the gear hub breaks. SOmetimes it strips teeth, sometimes it breaks teeth on the other gears (crank and distributor drive. If you really need to be certain of the problem, pull the valve cover and rotate the engine no more than 10 degrees each way with a socket on the front crankshaft nut. if the valve gera hesitates then moves, or does not move, toast it is. There are only a few thousandths backlash in the gears, and the valve train moves with no real slop with the crank. Jim
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
