Posted by Evan from Iowa on July 06, 2012 at 11:25:40 from (207.199.214.109):
I'm getting ready to put my 300 back together after painting it,and I want to make sure that I put my distributor back on so its timed right. My 1st cylinder is at TDC. So do I turn the distributor to the 1 mark and put it back on and try starting it? I don't know if this matters or not, but the pistons aren't flat-top. I dont know what a fire-crater looks like so I can't tell you if that's what's in it. Thanks, I'll post pictures when the project is done.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
