Posted by mkirsch on July 03, 2012 at 06:51:19 from (64.80.110.75):
In Reply to: INT. 300 posted by Bobinmi. on July 02, 2012 at 18:05:19:
Hang between gears, meaning hard to shift. That is an adjustment of the clutch and TA linkages. Your TA clutch is not releasing along with the main clutch.
Hang between gears, meaning getting stuck in two gears. That is a matter of building up the worn end of the shift lever, and/or shifting more carefully.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
