Re: 12v positive conversion to 12 v negative
Posted by Lewis Jackson on June 24, 2012 at 08:01:12 from (184.3.255.26):
In Reply to: 12v positive conversion to 12 v negative posted by lewis jackson on June 22, 2012 at 05:13:19:
will a standard 12 volt regulator work to replace the factory reg? one of my wires that sticks into the factory regulator broke and it needs replacing
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
