Well, I went through this two winters ago and it was a major failure. I found a metal retainer from a 450d and used a felt seal. You can't use a rubber seal with the spiral groove from what I have heard. Common sense tells you the groove will tear up the seal. You can't use a felt seal without a spiral or it will leak. That is just common sense.
So I soaked a felt seal in oil and used the metal retainer. All was well for about three hours and now it leaks like a sieve. The retainers appeared to run in the same spot. The crank was smooth from what I could tell. All that and it leaks more than it did with a warped retainer and a 50 year old seal. The only thing a lot of guys say is that it might have spun the felt. Was this because I used the new style retainer with felt??? Maybe
Sorry, no answers in all of this because I haven't had the time and patience to split the tractor again. If you don't mind a hijack, do I have to split an MD with the small clutch to drop the flywheel?
I use a torque table on all bolts that don't have a specified torque in the book. If I remember correctly for a 3/8 NC grade 5 bolt it is 27 ft lbs.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
