The words White Metal mean that it is some alloy of zink, tin, lead, cadmium, bismuth, and other low melt temp metals. The metal is often weak, brittle, or marginal for use in stressed structural places. If yours is flat, it is because it was not overtightened the last time it was serviced. There are many that show serious warpage and failure to. seal as a result of treating it like flywheel bolts (just kidding a little). If yours is flat, I would be thankful! Lay it on a piese of glass to check it. If you find a newer series unit, (check the location of the seal lip to be assured it is not running on the spiral grooves! And that there is smooth polished crank under the lip) If you cannot find one, and yours is flat, I would use it. Just remember not to reef it down. Jim
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
