Posted by jimb2 on May 31, 2012 at 17:18:25 from (99.241.38.122):
In Reply to: International 364 3Pth posted by Phil Tibbetts on May 29, 2012 at 14:59:49:
Hi Phil, Draft level always fully forward unless using some in ground implement like plow or harrow. To use the remote outlet, put 3pt lift lever in the middle of the Up and Down position and turn the Open/Close valve to Close, now if you move 3pt lever in UP direction the remote cylinder should extend and move 3pt lever in Down direction the remote cylinder will retract if there is a load on it(only UP pressure, Down relies on load on cylinder to push hydraulic oil back into reservoir). The Fast/Slow in Fast position allows 6 GPM oil flow to 3pt, in Slow position allows only 3 GPM to 3pt. I would use the Slow position when mowing with a 3pt sickle bar mower. If I saw a ground hog hole approaching by the front of rear tire, I would quickly move 3pt lever Upwards and then drop it again. That would lift the sickle bar up and over the ground hog hole and drop it again making a perfect cut without hitting rocks or dirt.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
