Posted by riverbend on May 28, 2012 at 04:40:23 from (70.101.159.161):
In Reply to: Cultivating corn soon. posted by Fullers Farmalls on May 27, 2012 at 20:17:28:
Find something on the cultivator that lines up with the corn row in front of you to use as a guide. Steering by looking at the corn as it goes through the cultivator is difficult.
Look at both rows now and then to be sure you are not burying one side and not touching the other.
Try to move a little dirt into the row. You can affect that by how deep you run, how fast you drive, and how close your sweeps are set to the row.
If you do fall asleep, back up and recultivate the patch that you just plowed out. That way it will look like the planter skipped...
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
