Posted by Owen Aaland on May 24, 2012 at 13:14:51 from (216.47.35.138):
In Reply to: 300 making noise posted by old on May 24, 2012 at 12:32:17:
To check noises with clutch bearings, with the pedal released the bearing should not be touching the release levers on the pressure plate and will not be turning so there will be no noise. As you start to press down on the clutch pedal when the bearing starts to touch the release levers the bearing will start to spin and any noise should start then. If you continue to press down on the clutch pedal until the clutch disk is released the pilot bearing will begin to spin as the disk slows down. By listening to when any noise starts you can determine which bearing is making the noise.
In your case the noise happens when the clutch is totally released so if you have the correct free travel in the clutch adjustment the noise is not in the clutch.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
