Posted by Doug - Iowa on May 22, 2012 at 19:09:23 from (208.126.0.19):
In Reply to: h misses a beat posted by jhakenwerth on May 22, 2012 at 14:55:49:
Mine does that a little. It has the Delco type of distributer that points up, not the IH type that mounts on its side. I blame it on the bevel drive gears being worn. Need to replace them one of these days I guess.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
