Is it easy to crank the motor by hand just after it dies? If not, then you have something seriously awry inside that engine, which will want serious looking into before it destroys something. If yes, then you have other issues. Not sure about the 6 volt system being the problem, because the tractor starts OK after a minute or two. Perhaps check the state of charge in the battery while the engine is running. If there is a charging fault, it may in fact be draining the battery or over charging it, both of which do not help with starting. As to the stopping problem, fuel issues and spark issues are the easiest to sort out and should be checked first if the motor is not tight to turn over by hand. Good luck.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
