Super M liftall and drawbar ??
Posted by gab on May 15, 2012 at 18:08:38 from (50.44.11.139):
Do you need to pull the pump out of the liftall and then stick a bar in the gears to get the nut off the shaft to repl the seal. The pict. in the I&T manual looks like you stick a small bar in the gears through a hole in the case.
Also I noticed on another Super M that the draw bar axle mounts are turned over from the way mine are which would raise the drawbar a couple inchs probably. The operators manual pictures and the parts book shows the brkts. flipped from the way they are on my tractor. I can tell by the pitting on the top eye bolts and lack off it on the bottom bolts that this is probably the way it always was and did'nt see any thing in the op manual about turning the brkts. for any reason. So which way should they be .
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
