Nope! This and the one in the background are definitely IHC. You can tell by the beams which were only seen on IHC plows. The plow in question on iron wheels has a steel "tail wheel" that does not provide depth or level control. The plow in the background is on rubber and has a depth control "tail wheel". Even new IH plows can be had to replace the probable "Plow Chiefs" shown on both plows.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
