The two bolts holding the starter to the bell housing. Unbolt them and wiggle the starter as the bendix mite be locked up on the ring gear. I would remove the starter and check all the teeth on the ring gear as you just mite have some bad worn teeth and the bendix drive will get locked up trying to turn the flywheel over also the teeth could be worn bad enough on the bendix putting a new bendix on the starter will not cure bad teeth on the flywheel but mite help.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
