It has a new battery in it and the posts were all cleaned on both ends of the battery wires and everything is in good shape there. I have had this intermittent problem before. Its just like the switch isn't making. The lights are bright and don't dim when I try to start it. But I don't hear anything from the starter. So, how does the switch come off? I guess I better go look at it. Maybe its obvious. Do I need to take the starter off to work on the switch or does the switch come off the top of the starter?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
