You would need the adaptor housing like used on a Super M without live hydraulics. M would have different bolt pattern except maybe very latest M. Timing is no problem as the dist drive gear comes right out of the dist reduction drive housing and you can put it in any place that timing lines up. Put engine on tdc, note where rotor is and points should be just breaking. Then put back together same place. This is basic static timing. A 450 should be times full throttle with a light to 25 degrees BTDC if it is factory yet.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
